CIUDAD XPERIENCE-SAT: You are not allowed to view links. Register or Login - You are not allowed to view links. Register or Login - You are not allowed to view links. Register or Login - You are not allowed to view links. Register or Login - You are not allowed to view links. Register or Login - You are not allowed to view links. Register or Login
Autor Tema: Openvix Zeus Vu+ ULTIMO  (Leído 969 veces)
Desconectado Predicador
  • Medio
  • Thank You
  • -Given: 7
  • -Receive: 31
« en: Abril 05, 2014, 04:54:36 pm »
vuplus-duo2-openvix-zeus-t178896
Proudly introduces a brand new ViX image for all OpenViX supported receivers.
OpenViX Zeus requires a full reflash. You cannot update from OpenViX 3.0 or use a settings backup from any image prior to OpenViX Zeus. We have coded it so that you can't use a backup from an earlier image as it will cause issues if you do.
So what is different in OpenViX Zeus then ?
The main difference is core of the image or the OE (Open Embedded); this has undergone a lot of changes, updates and fixes. As a user you should not notice any differences between OpenViX 3.0 and OpenViX Zeus. (i.e. there are no real functional differences. But as the last release is now over 3 months ago, several updates have been implemented).
Features
AutoBouquetsMaker ( ABM )Allows you to setup and automate the process of creating and maintaining a region specific channel bouquets for Sky (UK), Freesat (UK) and Sky Ireland (plus some European providers)
VIX EPG (includes CrossEPG 0.7.4)
Quite simply, OpenViX offers the best EPG experience of any Enigma2 based image bar none !!
Includes Graphical EPG, Text mode, Infobar EPG and Bouquet list graphical EPG modes
Video Playback
All EPG screens are now available while watching a recording, for easy switching back to live TV or setting timers.
Channel SelectionSupport added to change font sizes and number of rows.
Support added to have a 3rd event showing (Skin dependent)
Support added to display start time and end time for all events shown.
Quick PiP-ZAPSupport added to open PiP directly via long-Up/Down. Also zapping in PiP can be done via long CH+/-.
EPG Selection
Added help screen to all epg selection screens.
Added support to change font sizes and number of rows.
Language Selection
Added English (UK) to available languages.
Translations
Added support for English (UK).
Sorting
You may now sort Menus, Settings and Plugin Browsers alphabetically.
Network Browser
Uses less memory duringscan.
Moved to new Setup Mounts screen.
OpenwebifNew style webif now accessed using default port 80
Old style webif still available if required for use with certain PC signal meters and Fancontrol 2
About ScreenAdded network info.
Plugins As part of streamlining the image, removed NFS, AFP, Samba, OpenVPN, Inadyn, MiniDLNA & uShare from default image (can now be installed/de-installed through Network setup screen)
On Screen Hints Now available as options are selected.
Instant Record
From channel list, EPG or current channel.
Enhanced Movie List FeaturesIt is now optional to play next movie, when a movie reaches the end. Configure in menu of movie selection screen.
Known issues
    Crossepg bug when running XEPGDB and XMLTV within Crossepg. The software will not successfully download data from these sources due to incompatibility of crossepg and newer libraries within OE2.
Button Mappings
Short Red** & *** - Show current channel EPG info (ViX Single EPG).
Long Red** & *** - Sort single EPG info when in channel list.
Short Green** & *** - Timers.
Long Green*** - AutoTimer Timers.
Short Yellow*** - EPG Search.
Long Yellow*** - Instant IMDB Database search on the current programme.
Short Blue - Extensions.
Long Blue*** - Plugins Menu.
EPG - Opens ViX EPG.
 Left/Right
** - Opens ViX QuickEPG.
 Left/Right
 Up/Down
** - Open Full Screen Channel List.
 TV Button
 Long TV Button - Open Bouquets List.
** Can be changed in ViX Menu
*** Can be turned off in ViX Menu
Special Thanks
    Rytec - for his continued support.
    Ocram for his Picon sets
    All developers for their plugins used in the feeds of this image.
    All of the ViX Beta team for their hours of testing and dedication on getting this image working.
    Rob van der Does, Belierzz, Rimas, Henkka, Huevos, Raivo, Eesatfan, Zartmy, Trial, Stig-O & June8 for their translation work
    Huevos for his work on blindscan
    Gennart1 for dvb-as102 support
    Markus625 for skin ViXBMC
    Scwheeler for his work on the MetrixHD skin mods
    Rob van der Does for his skins, Magic Hd and Light
    Delagroov for his skins Magic Hd Night/No
Note:
Not all 3rd party plugins have been tested or are guaranteed to be compatible.
Requests
If anyone is interested in doing any translation work for the plugins and the image itself, please contact either Andyblac or Sicilian
« Última modificación: Abril 05, 2014, 04:56:01 pm por Admin »
